Install Help
How Do I…Find Ignition, Constant, and Ground Wires in Any Vehicle?
API Signal · Install Help · Tips and Tricks · Updated September 5, 2026
The basics chapter covers what a good install looks like. This chapter covers the tricks of the trade that make it faster, cleaner, and less likely to come back. Most of these were learned the hard way.
How do I find the ignition wire and constant 12 volt wire?
Use a meter, not a test light. Older test lights draw enough current to trip a body control module or set a fault code. On anything built in the last 20 years, a digital multimeter or a proper low-current LED probe is the only safe way to test.
Test ignition in all four key positions. OFF, ACCESSORY, RUN, and CRANK. A true ignition wire shows 12 volts in RUN and stays at 12 volts during CRANK. If it drops during crank, keep looking. Many wires that look like ignition are actually accessory.
Test under load when possible. A wire can read 12 volts on a meter and still collapse when the device pulls current. If a device reboots or drops offline when the engine cranks, the power source is weak. Move to a better one.
Ignition switch harness is the best source. For ignition and constant, the harness at the ignition switch or the main fuse panel is more reliable than a random wire in a door or kick panel.
Push-to-start vehicles. There is no key cylinder, so ignition has to be found at the fuse panel or through a fuse tap on a circuit that follows RUN. Test it the same way.
How do I use a fuse tap in a vehicle fuse panel?
How do I make a wire connection that lasts?
How do I pull wire through a firewall or behind a dash?
Where should I mount a GPS tracker in a vehicle?
What should I do before leaving a fleet install?
What are the most common causes of install callbacks?
  1. Tap connectors instead of solder or crimp.
  2. Ground on a painted surface.
  3. Ignition wire that drops during crank.
  4. Module hanging by its harness.
  5. Wire routed near a pedal or the steering column.
  6. Fuse tap on the wrong side of the fuse.
  7. Panels that rattle.
Avoid those seven and most callbacks disappear.
Install Help
More guides
