Install Help
How Do I…Install a GPS Tracker in a Fleet Vehicle?
API Signal · Install Help · GPS Tracker Install · Updated September 5, 2026
A GPS telematics install is three connections and a good hiding spot. That’s the whole job. What separates a good one from a bad one is where you get those connections, how you make them, and whether you tested it before you closed the panel.
This is the standard install we do on light-duty trucks, vans and cars. Heavy trucks get their own section further down.
What do I need before I start?
what a standard GPS tracker install needs
Have all of this on the seat before you pull a panel:
  1. The device and the right harness for it. OBD-II plug-in, OBD-II Y-cable, or a bare 3-wire pigtail. Know which one you have.
  2. The customer’s platform login, or a phone number for whoever can confirm the unit is reporting.
  3. A meter. Not a test light.
  4. A code reader. Read and photograph the codes before you touch anything. See the Codes chapter.
  5. Trim tools, crimper, heat gun, ties, loom.
  6. The work order, with the VIN and the unit’s serial or IMEI on it.
Write the serial or IMEI on the work order before the device goes under the dash. Once it’s hidden and the panel is back on, digging it out to read a sticker is a twenty-minute mistake.
Where should I mount a GPS tracker?
The device needs to see the sky and stay out of the way. In that order.
Good spots - Up under the dash near the windshield, above the pedals or behind the lower kick panel - Behind the glove box - On top of the steering column shroud, under the dash pad
Bad spots - Under a metal seat pan - Inside a metal center console - Down in a footwell where feet, mats and floor water live - Anywhere near the heater core or blower motor
Mount it label up, flat, unless the manufacturer says otherwise. Some devices care which way is up for the accelerometer to read harsh braking correctly. If the manual gives an orientation, follow it.
Zip-tie it to a factory harness or a bracket. Never let it hang by its own wires. A device swinging on its harness will chafe through the insulation on a rough road, and you’ll be back.
How do I install a plug-in OBD-II tracker?
OBD-II Y-cable install
The fastest install there is, and the one most likely to get pulled out by a driver’s knee if you leave it hanging.
  1. Read the codes. Photograph the screen.
  2. Meter the port: pin 16 to pin 4 should read about 12.6 volts with the key off. If it’s dead, the port fuse is blown and the tracker won’t work either. Tell the customer before you go further.
  3. Plug the Y-cable into the factory port. Never leave a fleet vehicle without a working OBD port, because the shop needs it.
  4. Plug the device into the Y-cable and tuck both up out of sight, above the dash lip.
  5. Secure the device and the slack with ties so nothing hangs into the footwell.
  6. Confirm it’s reporting, then put the panel back.
If the customer wants it hidden completely, run the Y-cable’s extension up behind the dash and mount the device out of reach. Same result, nobody unplugs it by accident.
How do I hardwire a GPS tracker?
the three connections on a hardwired tracker
Three wires. Constant, ignition, ground. Get them from the right place and the rest is easy.
1. Find the wires. Best source is the ignition switch harness or the fuse panel. Test every wire with the meter in all four key positions.
2. Make the connections.
3. Fuse the constant. Within a few inches of where you get it. The fuse protects the wire, not the device.
4. Wire the extras if the job calls for them. Auxiliary inputs for a door switch or PTO, an output driving a starter interrupt relay. See the Relays chapter for the fail-safe way to wire an immobilizer.
How do I install a tracker on a heavy truck?
Heavy trucks use a round 9-pin Deutsch connector, usually under the dash on the driver’s side, not an OBD-II port.
Look at the truck before you order the harness. Use a Y-cable so the port stays open for the shop’s scan tool. Everything else about mounting, grounding and testing is the same.
How do I hide the wiring?
Route along the factory harness and tie to it every 8 to 12 inches. Split loom on anything exposed. Nothing crossing the pedals, the steering column, the seat tracks or the airbag harness.
The driver should never know we were in the vehicle, except that the equipment works.
How do I test it before I close the dash?
Do all six. Every time.
  1. Meter every connection again.
  2. Key off, key in accessory, key in run, engine cranking. Confirm the device shows the correct ignition state at each one.
  3. Confirm the unit is reporting on the customer’s platform. Not “the light is on.” Reporting, with a location.
  4. If the device reads engine data, confirm the platform is showing engine hours and odometer, not just GPS position.
  5. Read the codes again. Compare against the photo you took before you started.
  6. Tug every splice and every tie. Put every screw back.
Then take your photos: device location, ground point, power source, fuse panel. They go with the job.
What goes wrong most often?
Every one of these is a callback we’ve been on.
Install Help
More guides
