Install Help
How Do I…Read a Resistor and Use One in a Vehicle Install?
API Signal · Install Help · Resistors · Updated September 5, 2026
A resistor limits the flow of current in a circuit. That's all it does, but it does it everywhere in a modern vehicle, and understanding it makes a lot of installs easier. Resistors show up in vehicle data lines, in device inputs, in bypass modules, and in our own test procedures.
What is a resistor and what are ohms, tolerance, and watts?
A resistor is a small, non-polarized part. Non-polarized means it doesn't matter which way you put it in the circuit. The type we use is the fixed-value carbon film resistor: a small tan or blue cylinder with colored bands.
Resistors are rated three ways:
Ohms. How much resistance. Higher number, more resistance, less current flows. The symbol is the Greek letter omega, Ω. Values are often abbreviated: 2,700 ohms is written 2.7k or 2.7kΩ.
Tolerance. How close the real value is to the stated value, as a percentage. A gold band means plus or minus 5 percent. A 2,700 ohm resistor with 5 percent tolerance will actually measure between 2,565 and 2,835 ohms.
Watts. How much power the resistor can dissipate before it overheats and burns open. Most of what we do uses quarter-watt or half-watt resistors. If a resistor gets hot, it's too small for the job.
How do I read resistor color bands?
Diagram: resistor color code chart
A four-band resistor reads like this:
Five-band resistors add a third digit before the multiplier.
Color Digit Multiplier
Black 0 x1
Brown 1 x10
Red 2 x100
Orange 3 x1,000
Yellow 4 x10,000
Green 5 x100,000
Blue 6 x1,000,000
Violet 7 x10,000,000
Gray 8
White 9
Example: red, violet, red, gold = 2, 7, x100 = 2,700 ohms, 5 percent.
When in doubt, put the meter on it. Ohms setting, one lead on each end. Faster and more reliable than reading tiny bands in a dark cab.
What is Ohm's law?
Volts = Amps x Ohms. If you know two, you can find the third. At 12 volts, a 1,000 ohm resistor passes 12 milliamps. A 100 ohm resistor passes 120 milliamps. That's the whole reason resistors matter: they set how much current flows.
How do I make a resistor value I don't have?
Diagram: resistors in series
Series (end to end). Values add. Two 100 ohm resistors in series make 200 ohms. Current capacity stays the same.
Parallel (side by side). Values divide. Two 400 ohm resistors in parallel make 200 ohms. Current capacity doubles.
For two different values in parallel: total = (R1 x R2) / (R1 + R2).
For data line and trigger work, the current is so small that capacity rarely matters. Series is usually the quick fix.
Where are resistors used in a fleet vehicle install?
Resistive multiplexing in older vehicles
Many vehicles, especially late 1990s through 2000s Chrysler, GM, and Ford products, control several body functions over one wire by sending different resistance values to the body control module. Lock might be 1,500 ohms, unlock 250 ohms, and so on. A device that needs to trigger one of those functions puts the correct resistor in line on that wire. See the Data Bus chapter for how this works.
Here are the values from the original guide. They are vehicle and year specific and were compiled in the mid 2000s. Confirm with a current wiring source before using any of them.
Vehicle Polarity Lock Unlock Factory arm
1996 Dodge Caravan, Plymouth Voyager, Chrysler Town and Country Negative 1,500 ohms 250 ohms 4,020 / 665 ohms
1995 and up Dodge Stratus, Chrysler Cirrus, Plymouth Breeze Positive 12 volts n/a
1989 and up Ford Probe, Mazda Millennia Ground 4,700 ohms 1,000 ohms
1999 Chevrolet Alero, 1999 Pontiac Grand Am
1998 and up Chrysler LHS, 300, Concorde, Dodge Intrepid 2,700 ohms 620 ohms
Device inputs
Some tracker and camera auxiliary inputs need a pull-up or pull-down resistor so the input reads a clean high or low instead of floating. The device manual will say so and give the value. Usually 1k to 10k.
Testing single-wire door lock circuits
Some vehicles use a single wire for both lock and unlock, with the direction set by resistance. To find the value the vehicle expects, measure resistance across the switch in each position with the meter, or step through values with a resistor assortment until the lock responds. Always start with a high value and work down.
Immobilizer bypass and key transponder circuits
Older GM VATS and Passkey systems use a resistor pellet in the key. The resistance must match one of 15 values or the vehicle won't start. Any starter interrupt or remote start work on those vehicles has to account for it. The value is measured across the key pellet with the meter.
What resistor values should an installer carry?
The values below come up most in data line and trigger work. Carry an assortment.
Ohms Bands
249 red, yellow, white, black, brown
330 orange, orange, brown, gold
390 orange, white, brown, gold
470 yellow, violet, brown, gold
560 green, blue, brown, gold
620 blue, red, brown, gold
750 violet, green, brown, gold
820 gray, red, brown, gold
1,000 brown, black, red, gold
1,200 brown, red, red, gold
1,500 brown, green, red, gold
2,000 red, black, red, gold
2,700 red, violet, red, gold
3,000 orange, black, red, gold
4,700 yellow, violet, red, gold
7,500 violet, green, red, gold
9,100 white, brown, red, gold
What are the rules for installing resistors in a vehicle?
  1. Direction doesn't matter. Put it in either way.
  2. Meter it before you install it. Bands are easy to misread.
  3. If it gets warm, go up in wattage.
  4. Solder and heat shrink, same as any other splice. Resistor leads are thin.
  5. Confirm any vehicle-specific value against a current source. Values change by year and trim.
Install Help
More guides
